help with airbag code please
Hey guys, so finally got one! phew. But i don't understand why it would have come on!!!! I left my car outside for one night at my gfriends house and the temp dropped down to -20...battery was low but car started. I heard a beep and boom AIRBAG light came on I did a search and said vag should reset it...wtf
Address 15: Airbags
Part No: 8D0 959 655 G
Component: Airbag Front+Kopf 1002
Coding: 00304
Shop #: WSC 63351
1 Fault Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
Address 15: Airbags
Coding: 00304
Shop #: WSC 63351
1 Fault Found:
RE: help with airbag code please
yea, you should be able to just reset the code...
its easy, just clear the code, they rent diagnostic eqip at autozone, clear it, and if comes back, then take it to a certified audi mech...
thanks for the reply Avant80
When I disconnect the negative battery terminal will this not reset everything? As in will I have to reset the idle and throttle body adjustment?
-Trav
-Trav
if the battery runs low like that and the airbag light wasn't on before that happened then it should reset if not then it has a fault, every time you start your car it goes through a drive cycle which sets everything up depending on how you drive so if you drive hard all the time it will set this way but if you let old Granny drive and she drives slow it will reset to that
