Help with 12v and 30v heads
Old 08-19-2006 | 02:16 AM
streetstruckk's Avatar
Default Help with 12v and 30v heads
I have a 96 2.8 12v a4. i want to know if its possible to swap the heads with a 30v engine, and if not just swap out the whole engine.another thing is will an exhaust for a 98 2.8 30v fit my car?
Old 08-19-2006 | 05:14 AM
Cameron's Avatar
Default RE: Help with 12v and 30v heads
No.
Old 08-19-2006 | 05:49 AM
AudiCross's Avatar
Swapping the heads, assuming they wouyld even fit, would require cam work, and a **** load of other stuff. If you are not happy with that situation, i would just suggest selling your car, taking ther money you have to upgrade your current one, and putting it together to but a newer, different car. In the long run, i believe you would be much happier.
And if you are to do something like this, make sure you make a good choice in year and model. Some have much more aftermarket choices, generally meaning less money and better quality because there is more money put into what money comes out of.
zGood luck.
Old 08-19-2006 | 07:12 AM
Trey25's Avatar
No to the first question, yes to the latter. Either way you won't be going very fast.
Emilgevor
04-19-2011 05:35 PM
R-bo
12-25-2010 04:05 PM
domino877
02-19-2008 12:44 PM
cvacc411
12-09-2006 12:36 AM
rbrtech
11-11-2006 08:38 PM
Quick Reply: Help with 12v and 30v heads
