Sponsored by:
Sponsored by:
Headlights fixed - a way to keep using a bad combi switch
Old 12-30-2012, 11:26 PM
ImTheDevil's Avatar
Originally Posted by v8_ranch
I am new to A4's. Just picked up a super clean 98 with the 2.8. Got the headlight combi switch issue though. Read your great thread about your fix, and wondered if you ever figured out a way to do this under the dash so as not have to remove steering wheel and airbag?
What you can do is add the wires as described above and run them to a switch under the dash. If your headlight switch is good, leave the under-dash switch off. If/when it melts, flip the switch to close the jumper and you'll have lights again. Alternately, put pigtail wires with blade terminals on the parking and low beam wires behind the headlights. If the switch melts, plug them in to jump them and continue driving.
ImTheDevil
01-31-2012 04:48 PM
tunaoue
01-07-2012 03:37 PM
Hecareth
12-22-2009 06:50 PM
kasimir99
08-08-2009 11:34 AM
Quick Reply: Headlights fixed - a way to keep using a bad combi switch
