headlight washer problem
I have discovered a weird problem with my headlight washer. I did long research and found nothing.
Here is the problem:
Headlight washers retract as they should, but instead of spraying with high pressure on the headlight, it kind of splashes everywhere without any direction, like a fountain. Please let me know , if its fixable. Thank you!
RE: headlight washer problem
thank you for your comment...The nozzles are there...although i dont know how to tune the so it hits the headlight...those plasitcs which i assume is needles, do have a tendency to pop out. what to do with them i dont know
You shouldn't have to "tune" the nozzles, if they don't spray correctly you have to replace the entire headlight washer to get the desired spray pattern. If you know how to pull the bumper its a snap to replace.
mcanedo92588
07-01-2013 11:27 PM
