Headlight switch replacement issue
Howdy.
I recently had my headlights go out. When I searched the forums I saw some posts about faulty headlight switches and my symptoms matched everything I read (high beams could be activated by pulling back, etc).
I ordered the part and replaced it today. Now my headlights work but my turn signals do not.
I even put the old switch back in and they don't work with it either.
They did work fine before I started.
My emergency flasher button activates fine and all the lights flash normally but I cannot get the turn signals to come on, either left or right.
I don't have an owner's manual but I checked the fuse that relates to the turn signal and it seems fine (I even switched it out just to be certain).
I don't see any broken wires inside the steering column area.
Any thoughts or ideas gratefully considered.
Thanks,
Andrew
1998 Audi A4 Quattro, 2.8l 130,000mi
Thanks,
Andrew
And the hazards do work when activated. Seems a little too coincidental that the hazard relay would just quit like that, doesn't it?
Also, another question... I see there is a part called the "Turn signal flasher" which has a Part Number: 7426-07113889.
Is that relay located inside the dash? I can see a few when I take the fuse panel cover off but I have no idea how you would get to them.
The 3 bladed turn signal flasher is like $10 on line while the hazard relay is closer to $70.
I did see some suggestion elsewhere for using a VW hazard relay because it's $15-20 cheaper.
Just wondering what the most likely scenario might be and how best to begin replacing parts.
I did pull the hazard relay out and cleaned the metal tabs but it made no difference.
Influentialstylez
03-29-2007 04:30 AM
