headlamp washers
headlamp washers
does anyone have any problems with their headlamp washers? mine dont work but if i were to play with themmanually, pulling them up and down i notice that fluid is escaping through the pump? also if i full up with washer fluid, eventually there will be a puddle on the floor when it passes the pump?
how can i fix this, and how doi know if its the pump and not the nozzles?
RE: headlamp washers
ORIGINAL: thintzen
I thought my headlight washers did not work till I found out the following. They only work with the following conditions:
A. You have your headlights on
B. You hold the washer stalk for about 5 seconds
C. It is 40 degrees F or cooler outside
When all three conditions are met, they work like a charm. Let me know if this works for you.
