Grounding Kit
RE: Grounding Kit
I never used 1 but they are for getting a better ground in the car when electronics are added like a system. I personally would'nt buy 1 since all you need is the wire (at least as big or bigger then what is there already) and connectors.
You would need wire for the following:
1) block to the firewall
2) starter to the battery
3) block to the frame
4) battery to the frame
5) alternator to the battery
RE: Grounding Kit
never tried them my self but they look good in blue
http://images.google.co.uk/imgres?im...l%3Den%26lr%3D
RE: Grounding Kit
.... And do remember to make sure you are Grounding components that have both a positive and ground, such as the starter and alternator, otherwise you will toast electronics real quick, not to mention have a really cool "fireworks" show.
