Going rate for 80K service...?
My First Post:
I have a new (to me) 2001 A4 1.8T Quattro and it has about 78k on it. Can you please let me know what the going rate is for a 80K service. I was quoted $615 by a dealership here in Tampa. Also if anybody knows a good shop in the Tampa area that I should check out please let me know.
One of the reasons that I want to have the service done is because I have a strange vibration or something on the right front. Feels like maybe a bent rim but doesn't. I can feel it more at low speeds and breaking/slowing than I can at high speeds. Let me know if there is anything I can check for before I get ripped off at the dealership. I am a bit upset because I didn't feel this when I test drove it and now is seems very apparent.
I will have more questions in the next couple of days. I trolled around for a few weeks while looking to get this car but now I have it and I will be actually posting.
-Pete
-Pete
RE: Going rate for 80K service...?
You'll probably get an expensive oil change. They should replace the spark plugs, pollen filter , air cleaner , ribbed belt and V-belt.
They'll do the timing belt at 90K mi. Good luck finding an independent shop. Ask people you know with German cars where they get service.
Another option is to DIY whatever you feel comfortable doing yourself. For example, OEM NGK spark plugs for the 1.8T engine are $11 each at RockAuto.com, but the going parts-and-labor rate for spark plug replacement at a dealership is about $120. Similarly, 4.5 qts. of Mobil 1 = $18 on sale, and you can buy the larger VW 068-115-561B oil filter or its Mann or Mahle equivalent for $7.50, giving you a proper oil change for the cost of a dino schlock job at Jiffy-Lube. The cabin air filter is a trivial DIY and another chance to save money, and the engine air filter is not that tough, either.
