Give up on my key fob.
Hello friends after a fight with my key fob i give up. So far i spend 200$ for nothing my problem still has not been fixed. My car will not respond to the key fob after running it on Vag Com and getting a faulty Central control module code. I then went and bought a new ccm installed it codded it with vag com and programmed the key the shop charged me 50$ to only tell me every-time they click the remote they got a lost signal error coming from the remote on vag com. Now i am clueless on what to do. Could it be my doors ? My driver door is acting up if i hold the key to the left the windows roll down but then they wont close when i try to hold the key to the right. My passenger door is basically invisible if there opened they never shows on the dash. When the alarm goes off the only thing that happens is the hazards turn on no actual alarm goes off.For me too lock all the doors u need to put the key in the door move it to the opening position to about 20 degrees then quickly to right other wise only the driver doors lock and 1/5 times the alarm actually arms itself.Some say its the key but every time i press it the light goes off on the locking button in the back seat so it seems the key is not the case. This are the codes i got few months back before the new CCM was installed maybe you guys can understand what happened
01463 - Alarm triggered by Sensor for anti-theft alarm System
9 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
37-00 - Faulty
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01559 - Drivers Door
59-10 - Can't Unlock - Intermittent
01560 - Passenger Door
01561 - Rear Left Door
01562 - Rear Right Door
if u got any clue on what to do help me out thank you
9 Faults Found:
37-00 - Faulty
35-00 - -
35-00 - -
35-00 - -
35-00 - -
