GIAC K04 Software is in!
And the car is simply awesome! The boost peaks at 22 psi and holds steady at 19-20 psi. However, when I hit about 5000 rpm under load, the boost "sometimes" (about half of the time) becomes very erratic.
Just got it done this afternoon, so I haven't had much of a chance to try to diagnose the problem. But here is what I observed:
1. High rpm with little load (~12 psi)--no problem.
2. Low rpm (<4500 rpm) with high load (~19 to 20 psi)--no problem.
3. High rpm (>5000 rpm) with high load (~18 to 20 psi)--erratic boost.
On the phone with the shop I'm told my MAF may be marginal and is intermittently weirding out (my words). I cleaned it tonight and may just order a new one, but has anyone else experienced this?
RE: GIAC K04 Software is in!
ORIGINAL: PandaXpress
did u get larger injectors or did u get the basic K04 programming
ORIGINAL: david9999
How many miles since you changed your fuel filter?
Ummm, what's that?
J/K I bought the car used and have not changed the filter. It has 58k on it now. Sounds like my Saturday is planned for me!
