Gearbox issues on an A4 Avant estate quattro
Hi, Can anyone help??
I have a 2009 A4 Avant Quattro and the problem is that when the auto gearbox gears down from gear 2, into gear 1... there is a jerking and juddering sound and the car feels like the power is going to die, but doesn't. However, if I use the paddleshift to gear from gear 2 into gear 1, then its fine. Any ideas chaps???
Thank you bigdog 7373 for your reply. To answer your questions, No, there are No lights on at the dashboard. Not too sure about the oil (but I have given it in for a gearbox oil change today). The valve body might need a replacement I was told by a mechanic, But I will defo get it cleaned up first to see if it makes a difference. Thanks.
dean weir
03-01-2015 11:26 AM
whartholt
11-18-2012 01:58 PM
MizzMac
04-15-2012 12:21 AM
