Sponsored by:
Sponsored by:
gas smell
Old 11-16-2006, 08:46 PM
carlosgtn's Avatar
Default gas smell
I need some expert advise !
I have a 2000 A4T 1.8. The timing belt and water pump were changed with all the other belts. A day later the CEL went on and the tech said it could be an evap line leaking. We had noticed a gas smell before coming from the trunk area. Any suggestions in trouble shooting the problem ?
Old 11-16-2006, 09:08 PM
CRAZYHAWK's Avatar
Default RE: gas smell
If the code is P0455 16839 it could be a loose gas cap.
It could also be an evap hose leak.
Old 11-16-2006, 10:20 PM
carlosgtn's Avatar
Any ideas about diagnosting the evap line leak ?
Old 11-16-2006, 11:29 PM
acetrebo's Avatar
Well, get the code first, so that hopefully give us a clue what its doing.
Is it running normally?
Old 11-17-2006, 12:34 PM
carlosgtn's Avatar
the car runs awsome. just the CEL is on and the gas smell is bothersome
Old 11-17-2006, 01:05 PM
acetrebo's Avatar
If cell is on, get the code. No sense in playing "guess me" because a lot of things could be causing it.
Old 11-17-2006, 04:34 PM
carlosgtn's Avatar
Tech found code P442 16826 any one knows what this is ? He also checked the top of the fue lsending unit ant its ok.
Old 11-17-2006, 04:42 PM
small leak in the EVAP system check all the pipes and clamps
Old 11-17-2006, 04:46 PM
carlosgtn's Avatar
Thats what the tech was thinking. now test with the smoke machine or is there any better way to test ?
Old 11-17-2006, 04:55 PM
cant argue with the smoky but can with their cost why cant they fix it when they find it, we all have to make a profit but this is stealing, im sure you would pay for a fix rather than a cheat, smoke test is a load of crap
Quick Reply: gas smell
