gapping spark plugs? doesnt make sense
#22
RE: REgapping spark plugs? doesnt make sense
ORIGINAL: rnbguy
im just gonna try .030 as 0.028 seems like its for a bigger turbo and the neuspeed chip isnt that powerfull
A lot of things go into making a chip "powerful", not just boost. If you are boosting a 1 bar or more (15+ psi), you want to keep your gaps tight or you will be replacing the coils soon.
#24
well i did it, changed em and regapped em to .028 (i was a little impatient and used the cement floor to close the gaps which scratched it a bit but that doesnt matter) anyway, no more stuter!!!!!!
i also found oil in there which im guessing was bcuz i had a leak valve gasket cover which i fixed with spark plug covers too... all good now
extra thank you for your help
if i had put the coil pack in wrong order whicih i doubt would i notice it when driving?
#26
ORIGINAL: rnbguy
sweet thanx
ill try .028 what are signs that show i should loosen the gaps?
also i see uve got a 1 bar neuspeed chip too, did u change ur FPR?
sweet thanx
