fuel noise (high pitch)
hi i recent just installed a fuel filter on my audi a4 Q, some how a day later i hear this high pitch noise coming from the rear end of the car? it sounds like it's something to do with the fuel lines or ??? I notice i did kink the fuel feed line alittle bit, but i already replace all the fuel line near the fuel filter. It somtimes comes on and later go away.. and somtime it stays one for quite a while. Please help!!! my email: yaj_jauni@hotmail.com i will be really appreciated Thanks!!!
RE: fuel noise (high pitch)
hey thanks for your kindly email of my Fuel Pump noise case... but thats a new oem fuel filter on my audi and that when i notice the noise. The filter was install correctly, but another case is that my gas needle tends to bounce up and down when my gas is about a quarter tank or 40% of gas left and i don't know if that is the case too? mabey i was running low on gas and that mess my fuel pump? also when i pinch the gas line near the fuel pump the noise goes away and when i restart the car the noise come right back??? please more help needed thanks!!!!
Thanks for the advice on the needle! but on my noise in the fuel pump humming, can it be the fuel filter that is causing that noise? or is it just the fuel filter going out? pinching the gas line once or twice the noise goes away but when shut engine off and turn on the noise high whistle or pitch comes back on and of and on......so tired of hearing that. please help again! THANKS MUCH!!!!
ORIGINAL: a4riderz
ORIGINAL: auditech79
Its your fuel pump making that noise, especially if its only doing it upon start up and goes away.
Double check to see if you got the fuel filter on right also.
u think the whining noise is annoying? i get squeaking noise all over my car when i drive. i can't turn the music up to cover it cuz ma rear speakers are pretty close to blowing lol. life sux. well wut if u tried starting the car with the fuel line pinched? u kno have sum1 start the car or sm? if it doesn't make the sound, then just keep it pinch with a hose clamp or sm. better than replacing the whole pump right?
Does anyone know, if i disconnect the fuel filter from the line and ran it strait witha adapter (Tee)to see if that stops my fuel pump high pitch noise? or to find out if the new filter is defected. would that mess up anything??? just for a quick start??? Thanks B5's
