Fuel in Engine Oil
RE: Fuel in Engine Oil
ORIGINAL: aRIf
Oil catch can catch the oil which goes back to the intake.
Fuel in engine should nothing to do with it, I think.
People in AZ say it could be compression rings. Ones I get it that close to the block, it'd be better to rebuild the whole thing.
onepoint8tee; do you have compression test stuff ? I wanna do compression test see what's up.
I got bored and I took the valve cover out;
And this is the cylinder head. it's all black there is like carbon on it it gets worst on the other heads step by step.
ORIGINAL: onepoint8tee
I thought when you run an oil catch can, it eliminates the pcv valve?
As for the compression rings being bad i really doubt it, un-less your getting close to 200k on the clock and im sure you use synthetic so it should be cool.
#18
I just finished compression test
I did 2 tests. Second test results are in the parantesis.
I think the reason first numbers are lower because I was little nervous to crack it.
Firewall
____
| 0 | -> 175 (180)
| 0 | -> 166 (170)
| 0 | -> 164 (180)
| 0 | -> 159 (186)
Front of the Car
Do they look ok?
Firewall
____
| 0 | -> 175 (180)
| 0 | -> 166 (170)
| 0 | -> 164 (180)
| 0 | -> 159 (186)
Front of the Car
Do they look ok?
#20
Ok, i just looked it up for your engine.
New engines 10-13 bar = 147-191psi
Wear limit 7 bar or 102 psi, so your engine is still bordering compression of a new engine, so the rings are out.
