Fuel in Engine Oil
Old 07-10-2007 | 12:00 PM
aRIf's Avatar
Default Fuel in Engine Oil
Why is that? I changed the oil about 800 miles ago and I start to smell the fuel in the oil. That's not good.
What seal or what cause of this problem? What do I need to replace it ?
Any ideas ?
Old 07-11-2007 | 01:12 AM
wood_e's Avatar
Default RE: Fuel in Engine Oil
Well... It could be that you're running way rich. Maybe worn rings...
Old 07-11-2007 | 01:55 AM
auditech79's Avatar
Change your PCV valve.
Old 07-11-2007 | 02:53 AM
wood_e's Avatar
^ that too
Old 07-11-2007 | 11:32 AM
aRIf's Avatar
Hope it is PCV.
Do you guys have any pic where it is located. It's not top ot my head right now. I want to check at mybreak.
Old 07-11-2007 | 11:54 AM
akielb's Avatar
PCV is directly abover the N75 - its the "puck valve"
also called the 034 valve in a picture on this DIY http://www.scottweese.com/images/pcv/pcv.html
Old 07-11-2007 | 12:06 PM
esandes's Avatar
Banned
the oil in my old lexus always smelled like fuel. the mechanics told me there's no fuel leak.
$0.02
Old 07-11-2007 | 12:24 PM
aRIf's Avatar
akielb, it's a great info. Thanks a lot. I think I found something to keep me busy this weekend
Old 07-11-2007 | 12:32 PM
onepoint8tee's Avatar
I thought when you run an oil catch can, it eliminates the pcv valve?
Old 07-11-2007 | 04:17 PM
aRIf's Avatar
Oil catch can catch the oil which goes back to the intake.
Fuel in engine should nothing to do with it, I think.
People in AZ say it could be compression rings. Ones I get it that close to the block, it'd be better to rebuild the whole thing.
onepoint8tee; do you have compression test stuff ? I wanna do compression test see what's up.
