Front wheel bearing and Radio problems...
I'm replacing the front wheel bearings on a 96 A4 1.8T. I'm wondering if there are any writeups on the subject.
Also, the code for the radio in the book was wrong. How do I reset the radio without the code.
Thanks
Josh
Flagstaff, AZ
Thanks
Josh
Flagstaff, AZ
RE: Front wheel bearing and Radio problems...
I found mine on a sticker in the spare tire well but not to everyone. Some dealers remove the sticker when they prepare the car for you. You can always go back to any Audi dealers to recover the code.
Two places. In the wheel well in the trunk should be the sticker with the car codes, paint, etc. In the lower left corner will be the 4 number radio code. It may also be on a small white sticker undr one of the cross membrs of the trunk
Thanks for the info. I was hoping there was a writeup out there with the torque specs and all.
I found the white sticker where the spare tire is. I'm going to try that code once the snow stops. Its different than the one in the little book. *rollseyes*
Josh
Josh
