front oxigen sensor
RE: front oxigen sensor
Its a very easy job. Pop the hood. Look on the left hand side of the engine when looking from the front of the vehicle. There is an exhaust manifold and a turbo. Look more toward the rear of the vehicle and you will see the oxygen sensor coming out of the catalytic conveter. It will have 4 wires. All you need is an oygen sensor socket and a long ratchet and youll make short work of it.
The rear o2 is a little harder to get to but its not bad. Its just a little further down the exhaust than the front one.
Nope, however if you dodn;t have the o2 sensor socket you can use a wrench but you have to remove the airbox which is easy. The rear 02 sensor is cake with a wrench dont even have to remove the airbox.
