fmic piping size!?
fmic piping size!?
quick question i have a fmic on my car that i did using a diy article on the forum in which the guy used a 2.5" inlet/out fmic, and on the turbo side used 2" piping and on the outlet side used 2.5" piping. i have run it for awhile with no complaints, but i noticed all the kits run either 2" or 2.25" ic piping on their kits.
QUESTION:
Is the 2.5" piping helping or hurting my performance? should i make it all 2.5" or 2" or keep it the way it is now?
QUESTION:
RE: fmic piping size!?
as in boost pressure? it doesnt appear to be dropping except of course the bleed off from a leak i have to find. does the 2" on the one side help or can i swap it all to 2.5" up to the inlet piping?
see i have run this setup for awhile and since i run stock software i was always at 9.5 psi i always had leak issues too and elbows popping off. then i upgraded the couplers and put t-bolts on. no pop offs but like a week ago it would hit 9.5 then slowly bleed down to 7 or 8. now it wont go any higher then 7 or 8. confusing...any ideas?
Does9.5 psisound like i had a huge pressure drop. maybe a 1/2 psi not sure what stock psi is exactly, i heard like 10 psi. i have dumped a bunch of money in this diy so far and the wife is gonna kill me soon. switching to 2" on both sides or 2.25 would be another 100 - 200 dollars. good couplers are expensive!
