Sponsored by:
Sponsored by:
Fitting Sat Nav to an A4 ( 2000 V Reg )
Old 05-31-2006, 03:26 PM
a4mad's Avatar
Default Fitting Sat Nav to an A4 ( 2000 V Reg )
Hi, I am thinking of buying an audi sat nav system as a direct replacement for the stereo I currently have fitted. I have the audi symphony system which is a double height size stereo & looks to be the same size as the sat nav systems. Does anybody know if the wiring required for the sat nav system will be in the car already or is this something which will need modifying / installing.
Regards
Old 05-31-2006, 03:27 PM
north5995's Avatar
Default RE: Fitting Sat Nav to an A4 ( 2000 V Reg )
Check the "DIY" section. I believe Jestomen had a go at it.
Old 05-31-2006, 03:29 PM
ejc317's Avatar
why nto get audi nav plus - its plug and play
Old 05-31-2006, 03:34 PM
a4mad's Avatar
Hi, Sorry not sure what you mean, DIY section where... Also who is Jestomen?
I think nav plus is for the newer A4 isn't? Do you think this will fit then?
Regards
north5995's Avatar
If you read his post... he wants to get an Audi Nav system. The first line "Hi, I am thinking of buying an audi sat nav system as a direct replacement for the stereo I currently have fitted."
There still is fitament issues.
Old 05-31-2006, 03:45 PM
ejc317's Avatar
You can get nav plus for b5's - jus tneed vag com to change some codes and take out dash to stick the antenna behind the meters
Old 05-31-2006, 03:46 PM
ejc317's Avatar
Well I figured he said he had the symphony audio system - in which case u get 4 clips - pull it out and stick in nav plus *shrug*
Old 05-31-2006, 04:10 PM
a4mad's Avatar
Thanks for your help guys, I'll give that a go.
Old 05-31-2006, 04:20 PM
Jestnomen's Avatar
6th Gear
Sigh come on guys. For all parts and tutorials you need to head over to http://navplus.us
Old 05-31-2006, 04:46 PM
brrman's Avatar
whats the address? how do I get there? I'f I had the NavPlus I could get the directions probably [8D][8D]
Quick Reply: Fitting Sat Nav to an A4 ( 2000 V Reg )
