finally fixed my fuel pump... but...
Old 07-21-2005 | 01:04 PM
rnbguy's Avatar
Default finally fixed my fuel pump... but...
i recently changed the fuel pump with the help of you guys, but i realised that when i drive my fuel gauge goes up and down too often im thinking i inserted the fuel sender unit the wrong way around, does anyone know which way around it goes?
Old 07-21-2005 | 01:42 PM
Jestnomen's Avatar
6th Gear
Default RE: finally fixed my fuel pump... but...
When I changed my fuel sender it would only go in one way. Maybe the sender is shot? It's a very common problem.
Old 07-21-2005 | 01:46 PM
rnbguy's Avatar
it was working before i changed the pump????
and i took extra care when removing it, when you put it in did it click when it went it, im thinking that long silver arm comming from the main unit, the one with the black sqaure hanging of it, maybe it shoulod be facing the inside of the car rather then towards the outside...?
Old 07-21-2005 | 01:48 PM
rnbguy's Avatar
to add to that i used vag-com and in the INSTRUMENTS SECTION, i recieved no errors.
jsethwerner225
11-14-2014 02:55 PM
turbo kraut
04-24-2012 08:28 PM
Notahondaowner
10-17-2007 04:47 PM
Indiepunk
09-25-2007 01:30 PM
Doose
09-04-2004 08:09 AM
