Filling transmission oil
Old 05-29-2006 | 10:35 PM
bixing's Avatar
Default Filling transmission oil
Hey guys..
I opened up the transmission gear oil by mistake... a real silly thing to do.. but the good thing is i realised it before i drove off my car to wreck...
But although i did look at the link in audiworld to fill the oil but I cant find the opening... http://www.audiworld.com/tech/misc.html
If you could let me know....By some another pic..
Mine is A4-1996 FWD 1.8T
Thanx guys
Old 05-29-2006 | 11:58 PM
djlouieboom's Avatar
Default RE: Filling transmission oil
[:@] that sucks man ill see if i got a better pic in my bently manual
Old 05-30-2006 | 01:22 AM
bixing's Avatar
hey thanx man..
lemme knw asap.. coz my car is at rest till then
Old 05-30-2006 | 08:48 AM
well the pics in the manual look like the pics from the auid world tech article sorry i wasnt any help did u search this forum ?
Old 05-30-2006 | 03:27 PM
bixing's Avatar
I found a bigger nut which needs 17mm allen to open....(I used the 8mm allen to open a nut just few cm in front of the bigger one which drained the trans fluid) ..
So Is that 17mm the one from where I fill in the fluid,..In that case I ll probably have to pump it back in thru there!!
Also could you tell me which type of fluid I need., I did check other posts... and one said to use oil specific to car?? wat does it mean --So could I use the one that is GL-5 specific??
plz lemme knw asap...
thanx
My car is audi a41.8t fwd 1996 model.
Old 05-30-2006 | 08:43 PM
bixing's Avatar
Hey guys...
Please tell me wat type of tranny fluid to use for my automatic... the dealer's are the biggest stealers.. they dont knw wat type of fluid it is..but all they knw is that the label says ..audi atf......$£^*$%&(*)
Please let me knw asap... i got a pump to fill the fluid ....
THanx
Old 05-30-2006 | 10:14 PM
CRAZYHAWK's Avatar
VW automatic transmission fluid that meets ESSO EGL 71141
they carry pentosin
http://www.ecstuning.com/stage/edpd/...ro&engine=1.8T
Old 05-31-2006 | 01:05 AM
bixing's Avatar
Thanx hawk... man u r always helpin me out..thanx....
I ordered those.... But I actually was looking for something I cud get the same day.... my bad luck. no one keeps it at any local stores..
Old 05-31-2006 | 03:24 AM
david9999's Avatar
You could go to the VW parts dept and pick it up. It is about 15 dollars a liter and you will need at least 2.
filling the tranny is a PITA. the car has to be level fluid slightly warm (49 degrees C with a VAG temp reading, and you have to squirt it into the fill area until it just overflows.
However, you have now changed the fluid (at least what was in the pan) and you are good for another 30K miles or so.
Old 05-31-2006 | 08:56 PM
CRAZYHAWK's Avatar
The tramsmission should be around 105 degees F. I have 106K mi. on the origonal fluid.
redsoxsurfer
02-02-2012 01:29 AM
virtualelvis
08-23-2009 12:27 AM
bprzybyl
01-06-2009 08:55 PM
tml
04-04-2008 01:42 PM
Grossbauer
07-21-2006 01:42 AM
