Fault Codes
Fault Codes
So I just got my car chipped today, apr 91 octane; what an amazing difference!
Anyways, while I was there they scanned my car for fault codes and found these two:
01119 - Gear Recognition Signal
35-10 - - - Intermittent
01039 - Coolent Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
Those are the codes as they show up on the Vag-Com. I didn't know if spacing had anything to do with diagnosing or if it was merely for aesthetics.
I am just curious if anyone knows the reason that I may be getting these codes.
Thank you in advance for any help.
RE: Fault Codes
So I just got my 710N installed today, and had them check my fault codes.
The following code popped up again:
Has anyone else ever seen this code or have any idea what I need to do in order to fix the issue; or is it even an issue?
Thanks.
Thanks.
