Sponsored by:
Sponsored by:
fan is in fan is in the way cannot get bottom of aternator bolt out
Old 10-01-2006, 12:33 PM
stanleymwilson's Avatar
Default fan is in fan is in the way cannot get bottom of aternator bolt out
fan is in way cannot get bottom of aternator bolt out is there any way i can move the fan back a couple of inches?
Old 10-01-2006, 12:50 PM
Default RE: fan is in fan is in the way cannot get bottom of aternator bolt out
the tension is spring loaded, some pictures down there that I put up ( try the search its a wonderful tool
https://www.audiforums.com/m_295957/tm.htm
Old 10-01-2006, 01:20 PM
thanks avant, got belt moved but i need to figure out a way to move the fan in front of the radiator backk a couple of inches so i can remove the bottom bolt of the alternator, any help is appreciated..
Old 10-01-2006, 01:32 PM
not easy on the A4 cant you line the fan up so it comes out enough to remove the alternator?? if its the twin electric fans they should be able to be unbolted and removed as a single unit
Old 10-01-2006, 01:48 PM
no the bolt is hiting the metal part of the fan.can the fan be removed?
Old 10-01-2006, 01:53 PM
not a lot of room there to remove it, the bumper will have to come off by the sound of it ( same as a timing belt replacement ) unless its a viscus fan and only one fan there??
Old 10-01-2006, 01:54 PM
Default RE: fan is in fan is in the way cannot get bottom of alternator bolt out
naaa the 2001 has electric twin fans im sure??
Old 10-01-2006, 02:12 PM
there is a hex bolt slot on the fan but it turns fan when i use it, do you think there is any way to take it off this way
Old 10-01-2006, 02:17 PM
so is it a single fan viscus type?? im not sure about the USA cars the UK type have the twin electric fans because of the aircon, can you post any pictures
Old 10-01-2006, 02:23 PM
dont have any pictures but it has a 8 mm slot in back it is definity one fan
Quick Reply: fan is in fan is in the way cannot get bottom of aternator bolt out
