Sponsored by:
Sponsored by:
failed inspection
Old 06-01-2006, 12:41 AM
Bbarn's Avatar
Default failed inspection
I failed my inspection because my check engine light iso n. I have the 4 codes that came up on my printout and was hoping I could find them out on here but I cant seem to find them. Anyone have a link to where I can find this out?
Old 06-01-2006, 12:43 AM
PandaXpress's Avatar
Default RE: failed inspection
ORIGINAL: Bbarn
just post ur codes here and someone will try to help u
hopefully Jestnmen comes by and see this
Old 06-01-2006, 12:46 AM
Bbarn's Avatar
1997 A4 Quattro 2.8L
P0170,P0173,P0171,P0174
Old 06-01-2006, 12:51 AM
P0170 - Fuel Trim Malfunction-Bank 1
P0171 - Fuel Trim, system too lean-Bank 1
P0173 - Fuel Trim Malfunction-Bank 2
P0174 - Fuel trim, system too lean-Bank 2
These codes are most likely caused by a bad MAF sensor or a major air leak. Could also be caused by bad O2 sensors.
Old 06-01-2006, 12:54 AM
Bbarn's Avatar
thanks alot!
How much you think this would run me to get fixed?
Old 06-01-2006, 01:00 AM
ejc317's Avatar
few hundred at most ... o2 sensor is easy to fix
couldn't it be a fuse?
Old 06-01-2006, 01:08 AM
Bbarn's Avatar
i really have no idea, this isn't my area of expertise, and im nervous to do it myself. I would be really happy if it was just a fuse, but for some reason i doubt it is.
Old 06-01-2006, 01:09 AM
toyolla86's Avatar
how do you find out those codes. i have an air bag light on. its supposed to mean something too.
so how do i figure out the code on that one. thanks
Old 06-01-2006, 01:12 AM
acetrebo's Avatar
Is it running OK?
Old 06-01-2006, 01:13 AM
Bbarn's Avatar
you can go to "autozone" and they check it for free
Quick Reply: failed inspection
