exhaust issue
exhaust issue
ok so when i was comin back from the beach the other day everything was fine until my check engine light turned on and began flashing. i couldnt remember wat it meant at the time but i was told to keep drivin with it cause nothin is wrong but it flashed a couple times later on the trip back and once i got home i checked the book and it says the cats may be damaged. so the main issue of this am i being lied to about nothin being wrong cause my engine starts to rumble and act weird when i accelerate . so should i have them replaced cause it happens at random
RE: exhaust issue
no sure about the o2 sensor might of been a misfunction or somethin i would have to get the sheet cause i dont have a vag com i only knew the o2 thing cause when i got some stuff fix i had them check out any codes and those came up but supposely the misfire is fine(3 different shops said it was ok)
RE: exhaust issue
well i found my reciept that has the cel codes on it ill list them exactly and wat it says next to it
code p0160- o2 sensor circuit bank 2 sensor 2
code p0301 cylinder 1 misfire
if u guys could determine wat the o2 sensor one means cause the guys never told me they just scanned it and charged me 45$ for the scanning
