Engine missing at idle
Old 11-25-2006 | 05:40 PM
Yaletown's Avatar
Default Engine missing at idle
I recently picked up a 2001 A4 1.8T. After the car warms up it tends to "missfire" while idling at a stoplight. Any ideas? I did a search of the forum but didn't find anything relevant.
Old 11-25-2006 | 06:23 PM
david9999's Avatar
Default RE: Engine missing at idle
Pull the codes. could be anything from a bad spark plug to a vacuum leak.
Old 11-25-2006 | 08:02 PM
CRAZYHAWK's Avatar
Could need a throttle body alignment.
Old 11-25-2006 | 10:00 PM
raimond's Avatar
...or throttle body cleaning...
Old 11-25-2006 | 11:24 PM
aRIf's Avatar
if the check engine light on, then pull the code from autozone or advance auto parts. they will do it for free. while you are there get yourself a new set of plugs NGK BKR6E.
Old 11-26-2006 | 12:54 AM
david9999's Avatar
Even if the CEL is not on there will be codes stored.
Old 11-26-2006 | 02:09 AM
scotia4444's Avatar
does it miss worse as you go up in rpm
it cold be that your sai is bad (letting air into your exhuast when deacelerating)
50mofo
07-31-2015 11:05 AM
k_twiford
03-26-2009 07:01 PM
Keithr726
06-09-2008 08:00 PM
iceman2002_uk
12-23-2006 11:03 PM
darrin
05-22-2006 10:19 PM
