Engine knock
Engine knock
I think the audi needs some maintainence shortly... it's been progressively getting louder and louder, but ONLY when i drive my car hard and i then stop and let it idle, i hear a loud knocking or tinging noise coming from the engine towards the firewall. I drive my car ALOT and need it for work... any ideas on what this could be?
Also, when i am driving and accelerate... as i pass 2600 rpms i hear a very light and soft whoosh noise come from under the engine bay. It doesn't do it at any other rpms. Any ideas? THANKS!
RE: Engine knock
It is an '01 1.8TQ 5-Speed. No mods. Just plain stock. When I baby the car, it doesnt make any noticable loud noises at idle... but after getting on it, it definitely sounds a but rough when it comes back down to idle. Not to mention, when i rev the motor up to 900 rpms the noise goes away completely. And I'm not sure if KNOCKING is the exact word to describe it... it more so sounds like a diesel motor.
RE: Engine knock
I have the same problem and the dealership diagnosed it as cam shaft tensioner. I had them do it and the noise disappeared plus my car seems to be running a lot better.
The tensioner is around CDN$700 and the install is about 5 hours.
RE: Engine knock
It is mildly too early to say whether this worked or not... but I picked up some Oil Detergent and Fuel Injector cleaner last night, and then drove my car pretty hard afterwards, and there was "diesel" noise afterward while it idled.... LETS HOPE THIS WORKS! I don't want to drop a few hondo on a cam shaft tensioner!
RE: Engine knock
ORIGINAL: CRAZYHAWK
When my tensioner went bad at 25K mi. ,I had a CEL.
Why would CEL kicks in when your tensioner is malfunctioning?
RE: Engine knock
My audi is doing the same...I have a 2000 a4 1.8TQ tip...
Ive been told it was lifters...or the common audi sludge problem causing the lifters to do so...
I wouldnt put any additives in b/c its not suppose to be good for our engines...plus cheap quick fixes never work...
Im thinking about looking into the camshaft b/c thats what it sounds like will solve it..
-T-
-T-
