Sponsored by:
Sponsored by:
Engine Flush - Amsoil
Old 03-18-2005, 12:11 PM
Jestnomen's Avatar
6th Gear
Default RE: Engine Flush - Amsoil
Yep that too. There was a guy on the 12v forum who ran an engine cleaner and later had all kinds of oil leaks/consumption.
Old 03-20-2005, 02:46 PM
DryFire's Avatar
ORIGINAL: trailboss
Justice Bros, i saw a post on audiworld about this stuff, research it for yourself to find more details. My next oil change im going to use it. linky
the link doesn't seem to work.
if the cleaner clogged up something else couldn't you run it again to clean that?
Old 03-20-2005, 05:15 PM
Doose's Avatar
Good point Jest. When I did mine I was having the clogged oil screen problem. It's never consumed oil, before or after I flushed it. At the time I did it out of desperation. I really didn't want to have to pull the pan and replace the oil pump. I drained two quarts of oil out, put in two quarts of ATF. I ran it for a hundred or so, drained, new filter, refilled with the same mixture of oil and ATF. Ran it for another 200 (I think) then drained it again. After all that, I still got an oil pressure light, so I pulled the pan (unfortunately it's not quite that simple) and replaced the pump and pickup.
Drew_Audi
04-24-2012 05:42 AM
ramses
04-29-2007 02:58 PM
JettaRedII
08-28-2005 04:07 AM
General Jackson
02-24-2005 02:57 PM
dudley doright
10-28-2004 11:29 PM
Quick Reply: Engine Flush - Amsoil
