Electrical problems - things are dying!!!
I'm having problems with an `00 A4, 2 months ago the airbag control unit was replaced (at almost $800), also the battery was replaced after it died ... now the wipers, turn signals, and heater fan do not work ... the rear defrost and heated seats work partially.
The headlights, both high & low, 4 ways, windows, brake lights and radio work ... except for "Run like hell" constantly scrolling on the screen ... is it an omen?
The voltage has fluctuated upto 16.
The turn signals were able to operate when turning the heater off ... but now, nothing and the fan indicator is sporadic.
All fuses look fine.
Any ideas? I'm going to have the altinator checked after work. It seems like there has been an electrical gremlin in this from the beginning.
Please, help ... it's going to be raining any day which will make driving without wipers ... well [:'(][:@]
Thanks
Ken
Thanks
Ken
RE: Electrical problems - things are dying!!!
alternator is a must in the check list.
I would also check out the fuses.
Good luck driving in the rain... if you have nothing on the windshield... try some wax (wax for the body of car) on the windshield... It helps keep the water off.
Has the car ever been flooded? I had a beater that was flooded and it did all sorts of neat electrical stuff.
The horn would work only when left blinker was on, and some thigs would work one day, then not the next and then work again.
Check the alternator though.
Check the battery too, i have had a new battery that did not work right, had a collapsed cell.
ORIGINAL: mastvadz71
ignition switch
ignition switch
get that rainx **** and put a ton on so u can drive in the ran, i love the **** i makes me feel like im in the millenium falcon and im travling at light speed, sorry that i really didnt ahve any input
Run a vagcom for codes.
Check the voltage with a digital volt meter, the car on, and all accessories off. If you are getting voltage over about 14.1 volts, you need a new voltage regulator.
