ECU upgrade question
Is there any way to tell by looking if an ECU has been "chipped" or upgraded. I bought my 1.8t used and am just curious. It seems to be a little fast for being stock and I have no way of contacting the previous owners. I'm the third owner. Is there anything on the circuit board of the ECU that is visually noticeable?
RE: ECU upgrade question
Remove the weather stripping and slide out the cover that goes over your brake fluid resevoir and battery etc. and the case for the ecu will be on the drivers side corner. Remove the screws and take lid off. You dont need to disconnect your battery as long as you arent disconnecting the ecu.
