ECU Swap from manual to tiptronic
Old 12-03-2006 | 05:22 AM
akielb's Avatar
Default ECU Swap from manual to tiptronic
Can anyone point me in the correct direction here?
I Have a 98 1.8t quattro tiptronic and I'm going to purchase an ECU with a GIAC chip from a 1998 1.8t manual - is there going to be any problem swapping ECU's. They have the same 557P Bosch #'s. I have a VAG-COM Cable (not registered).
Can someone give me a step by step of what I need to do for this swap to go right - Thanks
P.S. I have searched and couldn't find this specific question -
Old 12-03-2006 | 05:45 AM
Amze's Avatar
Default RE: ECU Swap from manual to tiptronic
is that possible?
Old 12-03-2006 | 02:43 PM
akielb's Avatar
Well I can only assume so since they have the exact same MFG part #. So if an audi shop/dealer ordered it, they would program it in house for each version. I was thinking that I would have to VAG-COM my car, write some info down and change the new ECU to that. am I totally wrong on this?
Old 12-03-2006 | 03:16 PM
scotia4444's Avatar
im going to go from an automatic to a six speed so. I will be swaping an ecu from a manual. then reprogram for the extra gear.
Old 12-03-2006 | 03:19 PM
Lazer Viking's Avatar
you can reprogram the chip from tip to 5 speed with vagcom... im not sure vise-versa but probably
Old 12-04-2006 | 03:36 PM
akielb's Avatar
Anybody know exactly what value's I need to remember from my ECU and change in the new ECU.
Old 01-03-2007 | 02:00 AM
bartvaio's Avatar
i want to do the same thing.
Old 01-11-2007 | 03:40 AM
akielb's Avatar
I think this is it - breaks down the softcode so you can modify it
AEB - http://forums.audiworld.com/a4/msgs/2466542.phtml
AWM - http://forums.audiworld.com/a4/msgs/2466561.phtml
Coletrain007
02-16-2014 01:07 PM
dha514
05-26-2008 04:43 PM
Mrog985
06-24-2006 02:06 PM
John814
03-27-2006 07:14 PM
davec
01-17-2006 06:20 AM
