Sponsored by:
Sponsored by:
ebay test pipes
Old 11-06-2007, 08:19 PM
apr_a4's Avatar
Default ebay test pipes
theese are cheeper but do they do they give the same performance?
Old 11-06-2007, 08:52 PM
ImTheDevil's Avatar
Default RE: ebay test pipes
Most likely they're fine. A test pipe is just a pipe with flanges on it. The only issue you might have (and I saw this with some downpipes and testpipes in the Z world), is that the fitment may or may not be good. Some guys bought them for their Zs and they lined up perfectly, but others said that the angles weren't right and they had trouble getting them to fit. Seems like it was hit or miss. But you'll probably be OK. You may find that the eBay ones are made with thinner metal or the welds aren't as high a quality though. Something to keep in mind at any rate. Power wise though, if they're the same diameter, chances are they'll make the same power.
Old 11-06-2007, 08:54 PM
onepoint8tee's Avatar
Go for it. I would have if they were available when I got my TP.
Old 11-06-2007, 09:33 PM
EliteTuning1's Avatar
i got mine off ebay, have not put it in yet but it looks great
Old 11-06-2007, 09:44 PM
njtrackstar's Avatar
sorry for this question in advance if it sounds dumb. But all the tp on ebay say for 1.8 engines. will they still fit a 2.8? i have a milltek exhaust but want something to bring the exhaust to life. Thanks.
Old 11-06-2007, 10:24 PM
Bogie's Avatar
no, the 1.8T test pipe is only for 1.8Ts.
Old 11-06-2007, 10:26 PM
AteUrV8's Avatar
a 3" pipe is a 3" pipe no matter where you get it, just make sure it doesnt look like its made outta wood lol
Old 11-07-2007, 10:11 AM
apr_a4's Avatar
all right im going to go for it, i had the same ideas as you guys did but i just decided to ask because ebay parts are genarely ****
Old 11-07-2007, 10:51 AM
turbo kraut's Avatar
Tech Guru
get it, let us know how it looks and works, then let us know which seller you got it through....... i am planning on doing mine in about a month or so
Old 11-07-2007, 02:54 PM
RaFa's Avatar
same here, been thinking of getting a TP from ebay, i did a search here in the forums,
andi saw a few people got it on ebay from the seller velocitymotoring. I have saved on my ebay,
just saving $ to get chip and some other stuff like a TP.
Quick Reply: ebay test pipes
