Sponsored by:
Sponsored by:
ebay short shifter?
Old 06-01-2007, 12:34 PM
docurley's Avatar
Default RE: ebay short shifter?
Here you go.
Before
After
I only used the middle setting so it could go lower.
  #32
Old 06-01-2007, 06:37 PM
Amze's Avatar
Damn, thats a huge difference
  #33
Old 06-01-2007, 11:50 PM
aRIf's Avatar
I finally did mine today.
It was a lot easier than whatI saw on diy pages. I did not need to go many things and adjustments that diy pages describe.
I have 1998.5 A4 1.8T.
It took about 1.5 hours because of I did not have hex socket wrench. I bought it after I'm done with the job to thight the bolds. You better have it before you start the job. It can save at least 40mins. (it's pita to put shift connections to transmission bolds back with L shape hex)
I used last hole which is the shortest.
There is before;
After;
This is everything I recieved but did not even used the most of that small things.
It fells great and it's so easy to do it, at least for 98.5 A4s.
I also didrandom open/close moonroof diy and fixed it very well, no more random open/close moonroof.
I feel like I have a new car
  #34
Old 06-01-2007, 11:53 PM
headshok2002's Avatar
This is one of those mods that you notice most when you drive another car WITHOUT a short shifter.
Row row row your boat!
Seriously, this will be the first mod for every future car I ever own.
  #35
Old 06-01-2007, 11:56 PM
aRIf's Avatar
totally agree with you headshok2002
I'm accually upset that why the hellI did notdo this mod long long time ago.
It's alot easier than changing oil.
  #36
Old 06-02-2007, 12:00 AM
ORIGINAL: aRIf
Yeah I did my dads, too... heh, got another good deal on a Neuspeed kit. I'd go eBay though, in the future. I can't imagine them having any problems.
But yeah, it's kind of a subtle difference at first... I swear, it's more noticable going back to a long throw car. They feel so gross!
  #37
Old 06-02-2007, 12:01 AM
acetrebo's Avatar
ORIGINAL: aRIf
Nice, I will have to consider this. I bet its sweet with the clutch you have.
  #38
Old 06-02-2007, 12:19 AM
aRIf's Avatar
acetrebo, if you do not have a ss, go and buy it from ebay. I have all the tool that you need to install ss.
We can even do it in my garage.
  #39
Old 06-12-2007, 05:16 PM
I have installed the e-bay ss and everything was fine till I went for a test shift through all the gears (with car off). I cannot seem to shift into 5th or R. I have been playing with the alignment of both the shifter brace bolt and the selector rod below. Is there something else I need to do to gain access to 5th and R? It seems as if the bottom shifter fork is hitting the side walls and not allowing access to 5th and R. Advice?
  #40
Old 06-12-2007, 06:01 PM
Lazer Viking's Avatar
i put mine in last week, and it worked, but i put the blue thing in upside down, and forgot the spring.. so it hit the bottom plastic thing.. so last night i took it out and fixed everything, works good now.. a little difficult to get into reverse though.. but i can deal with it
over all, did what it should shortened the shift, and shortened shfter length
cons, hard to get into reverse, and there is nothing to keep the shift boot up, there is also a little more verticle play then i would like
i'd give install a 5-10 because of the need for a few tools you may not have (circlip pliars, torx set)
but for a little over 30 dollars shipped, well worth it
sluggerjd
09-11-2009 01:53 PM
daghstdrummer
09-16-2008 11:21 PM
Dj Spiel
07-22-2008 04:11 PM
Bendet
06-28-2007 01:22 PM
BFlan2001
01-10-2007 07:48 PM
Quick Reply: ebay short shifter?
