Sponsored by:
Sponsored by:
E-Codes
Old 01-31-2005, 11:20 PM
flyboy's Avatar
Default E-Codes
I'm now in the market for E-codes and was wondering if the standard HID bulb will fit behind the projector, or do the need a shorter buld? Thanks.
Old 01-31-2005, 11:28 PM
Jestnomen's Avatar
6th Gear
Default RE: E-Codes
Define a "standard HID bulb". They come in a variety of sizes. The bulb used is a D2S xenon capsule.
You have two options. Buy the xenon ecodes that are meant for HID, or alter the halogen Ecodes demonstrated at http://www.oemhid.com/
Old 01-31-2005, 11:52 PM
flyboy's Avatar
Default RE: E-Codes
The HID's I have now are H7 bases made to work with OE 97 style headlights. I was Wondering If they were to long and would have interference with the projector or the shield that gives them the cut off.
Old 01-31-2005, 11:56 PM
Jestnomen's Avatar
6th Gear
Default RE: E-Codes
I doubt you'll have problems. Are they much longer than a standard h7 bulb? If not then they will fit fine. Are you goign to buy the xenon or halogen ecodes?
Old 02-01-2005, 12:00 AM
flyboy's Avatar
Default RE: E-Codes
I don't know and I was kinda wanting to avoid getting the bulbs back out and checking, but as for the E-codes, I'm not really sure. Another Q do you think these would work ok or do you know of any E-codes that are simeler.
http://www.procarparts.com/store-lis...6&cat=4&sub=31
The Black ones
Old 02-01-2005, 12:07 AM
Jestnomen's Avatar
6th Gear
Default RE: E-Codes
Those have much worse build quality than factory Veleo 1 piece Ecodes.
Old 02-01-2005, 12:09 AM
flyboy's Avatar
Default RE: E-Codes
I know, anythng with that look though. again the black ones.
Old 02-01-2005, 06:38 AM
BFlan's Avatar
Default RE: E-Codes
i've been looking for black headlights forever, i've found the ones you posted above, and some more at importvision.com. i've been told that they suck and have bad condensation problems. lltek has a new kit coming out that's black (two-piece), but it's not out yet.
Old 02-01-2005, 03:22 PM
sfordeso's Avatar
Default RE: E-Codes
you could also DIY. oven bake your headlights to seperate the lense from the housing. if your up for it, i can find you hte "how-to" step by step guide.
Old 02-01-2005, 08:42 PM
flyboy's Avatar
Default RE: E-Codes
That would be great if you could. but I would still have to get projectors.
Quick Reply: E-Codes
