DV install
RE: DV install
its a simple swap, only tools needed is a flat head screwdriver
removed lower splash gaurd
DV is located on pass side, trace the plumbing from the turbo down, you will see it just before the hard pipe that runs
across the front of the car below the radiator.
three hoses, two larger one small
