DV flutter
Old 07-11-2006 | 02:05 PM
kaklexicon's Avatar
Default DV flutter
For some reason recently when i'm in 3rd and 4th gear under heavy load and let off the gas kinda slowly instead of the DV going 'pshhhhhh' it flutters a bit. I've only noticed it under these circumstances though. Is that normal? Or is fluttering a sign of something not working right?
Old 07-11-2006 | 02:08 PM
onepoint8tee's Avatar
Default RE: DV flutter
Fluttering aint cool. Usually a sign of a boost leak somewhere.
Old 07-11-2006 | 05:31 PM
kaklexicon's Avatar
Dammit, i'll get it tested for boost leaks, if it is a leak .. I might blow my car up.
Old 07-12-2006 | 02:22 AM
shadeda4's Avatar
that sounds like a reason to use dynomite
Old 07-13-2006 | 02:13 PM
kaklexicon's Avatar
Ok so i went to my mechanic, no boost leaks... Any other suggestions?
Old 07-13-2006 | 02:46 PM
Get a boost gauge. Boost leaks can be hard to find, did he just vissualy inspect or use a boost leak tester of some sort? A boost gauge is a necessity with a turbo for diagnosing things like this.
EDIT:
Oh i see you have a boost gauge... What it read?
Old 07-13-2006 | 02:50 PM
a4autocrossr's Avatar
maybe instead of a DV...you installed a bird..and whenever you shift..it flaps its wings....??[8D].....yea..im not really sure...and if it turns out that this is the case....woah...sweet
--E
Old 07-15-2006 | 01:24 AM
kaklexicon's Avatar
lol yea it's a damn bird.. should have known. The boos seems to read pretty good. boosts up around 15 - 18 psi. I had him do a pressure test by the way. So there are def no leaks.... ?
Old 07-15-2006 | 01:37 AM
BaconBait's Avatar
Check the wires on the N75 valve and inspect your diverter valve.
bob1
02-10-2021 12:03 PM
makav3li
03-24-2010 11:10 PM
moeron7
03-07-2010 07:52 PM
rlubbers
04-23-2009 04:48 PM
holov
06-05-2007 08:23 PM
Quick Reply: DV flutter
