Dump valve questions
Hello,
Aliitle question from France
My car is a audi A4 1.8T Quattro , year 1996, engine type AEB.
The dump valve on my car is 9 years old ( same as the car in fact ) and is referenced: 034 145 710A
I'm thinking of mounting a 710 N bosch Dump valve which seem much better and much reliable.
Can you tell me is this DV is OK for my "little 150 HP " ?
Second question: Do i have to remove belly pan uder the car to access the DV or can i reach it simply by removing the airbox ?
Thanks a lot for your help
ytrezzzz
ytrezzzz
RE: Dump valve questions
You should remove the belly pan and it will be right there for you to change.
Many of us (incl me) use the 710N valve. It's perfectly safe and is more robust
than the stock A4 valve.
jamma
06-25-2006 12:46 AM
