Driverside Mirror problem
I am not even sure what to call this but my DSM has just started to change colors. It seems that someone hit it as there are two semi-circular compressions where the problem started. It started just after I had my upper tie rod ends and wheels and tires replaced by my local mechanic. I called asn asked if there was anyway he hit it with a wrench but he said no.
Well it need to be fixed. It is losing its dimming.
Does anyone have experience with this or know what is required to fix this problem?
RE: Driverside Mirror problem
you mean even the mirror housing? I thought lltek had replacement for just the mirror itself... I think lltek's was glass, too.
Mine are auto dimming, and my drivers side mirror is all screwed up... has condensation in it (foggy) and is very bronze coloured -- well, about half of it is
yeah i was told that the "bronze stuff" is the heating fluid that's inside the mirrors and if the mirror adjustor **** is left in the middle (at the white notch, not on either L or R) then it starts to leak, which ruins the mirror...sh!tty design
yeah that's what i thought too, so i just left it in the middle where it wouldn't do anything but my mechanic said that that turns on the heater, or somethin along those lines...
YEah, if you could find tell me where and exactly how much the part was that would be a big help...I looked at ecs and I am not sure if that is the right part but it cost 74.99?
