Sponsored by:
Sponsored by:
door misaligned
Old 03-06-2007, 09:01 PM
AF_guy_ram's Avatar
Default RE: door misaligned
Try tightening the door to frame bolts.....mine were loose, i had a water leak, and wind noice, mechanic at dealer sais the door frame was bent and neededreplacingbut after I tightened the bolts, the wind and water leak stopped....imagine that huh?
Old 03-06-2007, 09:12 PM
crosswire's Avatar
I noticed that the bolts may be loose, I may give that a shot. Thanks guys.
Mike
Old 03-07-2007, 12:24 AM
scotts custom's Avatar
ya i just fixed my door.
you have to screw down the bolts that hold the door to the frame. they are on the frame. that little hinge thingy. and if they are already tight, then look at the little notches next to the hinge and line the hinge up the best you can.
hope this helps
Old 03-17-2007, 08:48 AM
I had the same on my 96 A4. Cause was the door being whipped out of my wife's hand by the wind, putting a slight twist in the hinges.Adjustment improved it, but I neverdid get it perfectly wind tight after this.
AudimaniaA4
08-01-2014 02:35 PM
dvmorris
03-26-2013 02:47 AM
crosswire
03-06-2007 02:18 PM
98A4V6
12-10-2005 02:21 AM
Quick Reply: door misaligned
