Do NOT get a Revo Chip.
#21
RE: Do NOT get a Revo Chip.
no offense but ant chip can put strain on the rest of your components causing them to go bad. That's one of the hazards of chipping. The dealer sounds like a tool though. He can't charge you for all those hours of work if the job should only take at the mose 45 minutes. Next time make sure you get a quote in writing first before you have the work done then it can take him until next week and he will only be able to charge you for what he quoted you. I don't use Revo but I highly doubt that is there fault a crappy dealer is installing their stuff.
#22
ORIGINAL: EVOLA4
#24
while were talking about coilpacks...
whats the diff between L.. R.. and E coil packs?
I've been reading on zine, and they are scared sh#$less about their coils failing. So, i was about to order some hitachi's, but then it said E style coil packs.
Can someone elaborate the meaning of the letters?
Thank you.
Thank you.
#26
ORIGINAL: kolan67
Thank you.
They are just up-dated models of coil packs, but they all suck. The company that makes them are on crack or something that they can't make a decent long lasting coil.
Thank you.
#29
i put the old style hitachi "e" coilpacks on right before i got flashed... because they are known to go out with the additional strain from the chip... not because of REVo and by your own admittance, they were not an authorized REVo rep so i wonder how they even got the software???
i think u are passing the wrong blame...
and the L and R versions that come on B6s are the newer style... with R being the latest revision without a recall... the hitachi E coils are actually the old style designed for the b5s.. Es bolt down as well and are not even remotely prone to failure
#30
ORIGINAL: Papachristou
