DIY clear corners (one piece)
RE: DIY clear corners (one piece)
ORIGINAL: clconversion
its not that bad took a bit of time to pry the lens from the corner that was about it
It was actually not that hard to do, once you get the orange piece free, just use a new needle nose pliers and brake it into small bits, just don't scratch the chrome. But when you are done, DO NOT drop the light onto the driveway as you are walking up to the car to put it back on![:@] It was about a 4 beer job.
ORIGINAL: Kellya4
"So let's see here.....timing belt on a 2.8, geez that's gonna be a case and a half to do that job." Yeah, it took about 3 hours to do the clear corners, but you will love the results. When i was freeing the orange plastic lens, i didn't drill them out as the directions said, i used a coat hanger and heated it up to melt the three plastic tabs free, it makes a much smaller hole. If you are careful, the hole where the tab was will be very small.
