Display LED going faded
Has anyone had the LED display going faded so it can hardly be read in daylight?, (the one on the centre console showing fuel consumption,outside temperature etc)
Can anything be done about it, except getting a replacement for £400.......
RE: Display LED going faded
Honestly never heard of it fading before. It sounds like an R&R type deal - usually those sorts of things are one piece and aren't worth the effort of taking apart to fix. Maybe you can get the part and do the R&R yourself.
Yes I have seen that a lot probley once a week a car comes in with a fadded DID (driver information display) and the tech will just replace the whole unit I just hope your car is still under warrenty that instrument cluster is ushally around $900.00 canadian
My display is starting to get lines through it a bit. It's really not a necessity it's for show and if you want to shell out some $$ then get it repaired but other than that forget it.
i just purchased an instrument cluster off ebay a couple months ago for $100US. The odometer can be rolled forward one time with a VAG-Com. That's an option for you. If you are really technically gifted you can buy a used one and remove the display. There have been some posts on audiworld about this.
david9999
01-27-2008 11:51 PM
