Disconnecting battery?
Old 05-17-2006 | 12:37 AM
a4sport's Avatar
Default Disconnecting battery?
I need to disconnect my battery for a extended period of time to redo my front end. I need to change rad support and other thing too. I will be disconnecting the battery, so that the airbags don't deploy for any unknown reason.
So, is there anything that will reset that shouldn't when I disconnect my battery? I don't want something to get messed up that shouldn't, all because I disconnected my battery.
Old 05-17-2006 | 12:39 AM
cary12's Avatar
Default RE: Disconnecting battery?
Just make sure you have your radio code. Your radio will go into SAFE mode and you will need to use the code to unlock it.
Old 05-17-2006 | 12:45 AM
onepoint8tee's Avatar
Your automatic down/up windows feature will need reprogramed also along with your clock.
Old 05-17-2006 | 01:11 AM
a4sport's Avatar
Damn it. I knew I'd need to do more than I should. LOL. Audi's, I tell you.
I have the radio code, how do I reprogram it?
And now to the windows, how do I get it reprogrammed without taking it to the dealer?
Old 05-17-2006 | 03:50 AM
Sp33d07's Avatar
both ahppend to me bro tell you rite now.
your radio code is four digit code. when the radio displays safe, you press the rbds and rdm or sumthing cant remember but its the two buttons that star with R on the right sdie. then put the code in by using the numbers 1-4 to increase the digits. then hold the two buttons again you are unlocked.
the windows, hold it till window goes all the way down. then after window is down hold it till window goes all the way up. they should start working like before. belive me i went through all the crap because i had to disconnect the batter when i was putting my system in but didnt have the radio code.
Old 05-17-2006 | 04:00 AM
acetrebo's Avatar
like he said.....
I think I put my key in the door and made it close (or open?) all the windows, that reset it back to normal for the windows.
try seacrhing for this stuff, its already been talked about many times.
Old 05-17-2006 | 04:10 AM
BadLuckAudi's Avatar
its probably something your gunna have to do with a vag come, the key thing doesnt work unless its been reprogramed or it never forgot it
cwedholm1
03-30-2010 05:30 PM
shayrgob
10-03-2008 10:17 PM
millenia
09-25-2008 10:22 AM
eliTTe
03-21-2008 01:01 PM
Alexa4
03-29-2006 02:01 AM
