difference between tires plz reply
RE: difference between tires plz reply
ORIGINAL: chaos92287
ok i just did some quick reasearch and i think its ok to do that. the speedo will probably be off 1.25% or .74 mph at 60mph but thats nothing
diameter + or - several inches...
I might be wrong though...
First set of numbers is width of tire. Basically it's footprint on the road.
Second set of numbers is the sidewal height. Meaning that if you go higher in numbers the more sidewall you'll have. So 235/40/18 is the same height as a 225/40/18.
Third as we all know is rim diameter.
Hope that helps you. Only difference between a 235/40/18 and a 225/40/18 is width of tire. That size tire is fine for your car if you want to save money.
