Difference between suspensions?
RE: Difference between suspensions?
why would you go out of your way to confuse yourself with s4 suspension?
there are lots of suspension setups you can run designed for the a4. some are stiffer than others.
just look into a4 kits so you don't need to worry if there's a problem or not.
doesn't that make sense?
laoma
01-26-2012 12:22 PM
