difference between 1.8T engines
Hallo,
I saw in Dahlback site about chip tuning. And there I read this:
"The above specified torque 236lb-ft is valid for 97 cars. On 95-96 cars the torque reaches 212 lb-ft and from 98 and onwards the torque reaches 260 lb-ft."
Can you tell me what is the difference between this engines. What are their designations?
I want to buy A4 B5 1.8T 150hp and I wonder which engine is better
RE: difference between 1.8T engines
are you sure those are audi motors they are talking about?
cause the audi 1.8 motors from what i recall....... all 1.8's prior to the awm motor were 150bhp, the awm moved up to a wapping 170bhp
but the vw has a 180bhp and i think 190bhp motor
everything that I quoted is about Audi 1.8T 150hp engines.You can see it there anout Audi A4 1.8T stage 1 http://www.dahlbackracing.se/english/main.asp
ORIGINAL: chaos92287
sounds like they got their years mixed up. anything pre-00(aeb engine) should be the same, the 00 and 01 should have different results due to the k03s
99-00 have 150hp
2001+ 170hp
pre 00 does have the AEB with the larger intake ports.
2000 has the ATW, whis basically an AEB with small intake ports, 19mm wrist pin (AEB has a 20mm), and it's the first year with throttle by wire. It still has 150hp.
01+ has the AWM. They changed a lot on the bottom end of the motor for the accessories, the head has variable valve timing, and one or two other things I can't remember off the top of my head that up the hp.
exactly, pre-00 should all have the same results cause they all have an aeb engine and regular old k03. i thought the k03s was introduced in 2000 for some reason. guess i was mistaken. but in 01 they added the k03s, changed the programming by .2 Bar, and lowered the compression slightly. VVT is for emission purposes only, not adding power
ORIGINAL: turbo kraut
http://tuning.3x.ro/audi.html
AEB-stock 150hp 210nm... with chip 187hp 280nm
ANB, AGU, AWT, AUM, APU, AVJ- stock150hp 220nm ...with chip 195hp 287nm
AWT, AQA, ARZ- stock 150hp 215nm... with chip 210hp 300nm
http://www.autoshoppingcenter.com/Vo...ginescode.html
