Detonating 1.8t?
Old 08-23-2006 | 07:04 PM
onepoint8tee's Avatar
Default RE: Detonating 1.8t?
Stock or chipped, the engine shouldnt detonate unless something is wrong like a vac leak or bad maf or something unrelated to the ecu's tuning.
Old 08-23-2006 | 07:06 PM
MC Hammered's Avatar
If you don't have an IC it would help.
If it is pinging without a chip, chipping the car might make it worse since you are running higher boost levels.
From what I have gathered you might want to check your spark plugs and fuel filter as it might be clogged if it has never been replaced
Old 08-23-2006 | 07:27 PM
blkapra4's Avatar
i will attempt this this weekend. are fuel filters??? do you recommend the oem plugs?
Andyrew
07-04-2007 07:38 PM
