debadged but..
Old 07-06-2006 | 03:14 AM
juice88's Avatar
Default debadged but..
well i just debadged the a4 badge to see how that looks and i was then going to decide if i want to take off the 1.8t. well i did the debadge but if u get close, u can see an outline of the A and 4. idk what to do to get this off...help!!!
BTW- i followed the write up on here for the diy and i repeated the process of heating the area then applying the goo remover then rubbing. maybe im doing something wrong
Old 07-06-2006 | 03:48 AM
VB05's Avatar
Default RE: debadged but..
ORIGINAL: juice88
it won't all come out right away, you can also use some compound with a buffer wheel (if you have one). it goes away eventually
Old 07-06-2006 | 03:51 AM
dan's Avatar
dan
could also try something like scratchx by hand, it should help a lil
Old 07-06-2006 | 03:53 AM
VB05's Avatar
yea, there is alot of stuff out there...i used this stuff called "Oops!" that worked pretty well. You're gonna see a little outline no matter what, but it fades.
Old 07-06-2006 | 04:15 AM
ejc317's Avatar
use paint cleaner and then polish then wax
it comes off rigth away
Old 07-06-2006 | 05:05 AM
endle55's Avatar
DO NOT U PAINT CLEANER, ALCOHOL, PAINT THINNER OR ANY CLEANING SOLVENT
It will eat away at your clear coat paint, and cause your paint to fade and dull away, in extreme cases rust.
Just get some fine grit polish and polish it out.
Old 07-06-2006 | 05:53 AM
ejc317's Avatar
errrr i meant paint cleaner as in the mcguire's paint cleaner ... not thinner
Old 07-06-2006 | 11:43 AM
smokeU's Avatar
use some good ol fashion elbow grease!
CrazyBignate
01-29-2014 01:15 PM
SilverA4q
08-27-2007 03:47 AM
BlkQ
04-25-2007 10:19 PM
Russ03A4
03-15-2006 05:05 PM
StepUpProductions
01-12-2006 05:09 AM
