DBW?
RE: DBW?
there used to be a big draw back to dbw cars, since the throttle is electronically controlled
but they only reason you would have a problem with that now is if you were running full standalone with a big turbo, then you would need drive by cable
most of the software available now has figured out the coding to run on dbw ecu
i dont know why you would want to convert dbc to dbw.. theres less stuff to screw up with dbc, and dbc is somewhat more responsive (not noticbly)
